Here are catalogue pages for the some of the many signal conditioning boards that were made.
Arcom originally designed a 50-way connector pinout, but another company made a 60-way superset which they named the Signal Processing bus.
If designing new boards, I would use the 60-way connector because has an even number of pins either side of the board centre line. If using the 50-way connector, place it sits in the subset of the 60-way connector. This will not be symmetrical about the centre line, but that helps keep cabling between the two types free of bends.
![](https://cdn.hackaday.io/images/9553731703957920219.png)
![](https://cdn.hackaday.io/images/7512501703957912780.png)
![](https://cdn.hackaday.io/images/1362941703957911721.png)
![](https://cdn.hackaday.io/images/7916001703958568024.png)
![](https://cdn.hackaday.io/images/8315091703958598364.png)
![](https://cdn.hackaday.io/images/6390501703958046446.png)
![](https://cdn.hackaday.io/images/8832881703958108638.png)
![](https://cdn.hackaday.io/images/3353891703958131124.png)
![](https://cdn.hackaday.io/images/2175981703958170263.png)
![](https://cdn.hackaday.io/images/192891703958261296.png)
![](https://cdn.hackaday.io/images/3936661703958281241.png)
![](https://cdn.hackaday.io/images/3153451703958325541.png)
![](https://cdn.hackaday.io/images/6094341703958348698.png)
![](https://cdn.hackaday.io/images/1017021703958367772.png)
![](https://cdn.hackaday.io/images/438201703958388227.png)
![](https://cdn.hackaday.io/images/1223481703958407371.png)
![](https://cdn.hackaday.io/images/5645051703958440404.png)
![](https://cdn.hackaday.io/images/2634601703958478842.png)
![](https://cdn.hackaday.io/images/8410071703958498923.png)
![](https://cdn.hackaday.io/images/2595051703958519712.png)
![](https://cdn.hackaday.io/images/209281703958621001.png)
![](https://cdn.hackaday.io/images/9813961703958642707.png)
![](https://cdn.hackaday.io/images/1115971703958664624.png)
![](https://cdn.hackaday.io/images/449271703958695462.png)
