I was recently able to reclaim 2 bytes in the integer parsing subroutine. With these two bytes I’ve added support for colon as a statement separator. Multi-statement lines were already allowed with no separator between statements. Adding the optional colon makes this slightly more compatible with existing programs.
I’ve also added the file errorcodes.txt to the GitHub project, to explain the code and meaning of the 16 different error codes that can occur.
