Which minitels are compatible ?
A project log for MiniPlay: Minitel Gaming System
If the Minitel was a video game console, this would be the cartridge !
louis-hLouis H 02/11/2024 at 16:000 Comments
Even if the code is compatible with early version of minitels, the cartridge needs to be powered from the DIN port to works. Unfortunately not all minitel provides that power source.
The table hereafter is extracted from STUM 2. Not sure how to recognize the minitel model visually, but this is a good start to check which minitel are compatible !
