The full (current) feature list:
- Web-Interface for Monitoring and Setup
- SD-Card support for loading of Config/Logging Data
- Config internally saved
- Up to four plant channels
- Two different operating modes for each channel:
- Moisture Control using inexpensive Capacitive Soil Moisture Sensors
- Timer Control for sensorless operation
- 12V Pump Support (I used a membrane pump)
- 12V fluid valve support
- USB-Interface for debug messages (later rudimentary control)
- Spillage Sensor for emergency stop (flood prevention)
Of course because the Project is still in development and testing, some features will be changed or new features added.
New features might include internal water consumption calculation and more intuitive web interface.
Synthron
Isaac Hayes
Evan Salazar
Moran Assif
Have it send you an email when the reservoir gets low?
