Breadboard the ccTalk Interface
A project log for Un-Inhibiting my Microcoin QL
Let me describe how I got my Microcoin QL coin acceptor to work.
mikeMike 02/19/2024 at 16:140 Comments
Bottom Line Up Front
The ccTalk interface circuit. was built on a breadboard with a few components. This was straight forward. Well almost.
TL;DR
I substituted the following components for those specified. If it didn’t work, I’d have simply ordered the right part. But since the resistors were really only being used as switches, and the resistors only being used as voltage dividers, I was fairly confident it’d work:
Component
Specified
Substituted
Schottky Diode, low forward voltage drop
BAT54
1N5817
NPN, high gain medium signal transistor
BC846B
2N4400 general purpose
PNP, high gain medium signal transistor
BCW68
2N4403 general purpose
Resistors ¼ W
68K
57K
And the breadboard:
And it did not work. Recall that my serial adaptor only outputs 3.3V. The interface circuit is designed for 5V. Now, I could include an image of the wonky signals from the oscilloscope, but let’s move along. I inserted a voltage comparator in between the adaptor’s Tx and the Tx of the ccTalk interface circuit.
