How much did it cost?
A project log for The Tile Job
Adventures of a software guy doing his first bathroom tile re-do.
wjcarpenterWJCarpenter 04/07/2024 at 23:120 Comments
Before I started, I SWAGged this at being under US$500 and taking me about 3 weeks to do it. Let's see how we did.
My time and labor were free. The opportunity cost was only delay in other DIY and hobby projects. The time was between 5 and 6 weeks, but that is mostly because I only worked an hour or two a day. I had to spend a lot of think time for things that experienced people would have just taken in stride. Part of the time was spent on things that were not tiling, per se: the plumbing and the sliding glass doors.
There are a couple of mitigations on the cost of tools and materials. My main shopping was at Home Depot, Lowes, and Floor and Decor. At Home Depot and Lowes, I get a 10% discount on almost everything. They are confident in making it back on things I screw up or otherwise need to re-do. In the cost figures below, I am mostly ignoring things I had to buy more than once due to goofs or poor workmanship. I have a separate accounting for tools and supplies that could be used for future projects. But, on the other hand, I'm also not counting things I returned, either because I decided to not use them or because I bought too much. Figures are appoximate.
ItemCostNotes
Carrara tiles (12x24), 5 cases150Includes most of a case for the test wall
marble trim tiles (4x16), 4 pieces20niche trim pieces
Edge trim (2x36), 6 pieces60manufactured stone sills
Wood look tiles (6x24), 8 pieces16shower tower and niche back walls
Lumber25grab bar backing and niche framing
Wood screws10
GoBoard (36x60x0.5), 4 sheets100
Marble penetrating sealant18For niche trim. Had to buy a pint and only used about half an ounce.
Backerboard screws12
Backerboard washers20
GoBoard sealant, 2 tubes25
other sealant, 5 tubes55temp local shortage of GoBoard sealant
RedGard, 1 gallon701/3 to 1/2 left over
Pre-mixed grout (1 gallon)601/3 to 1/2 left over
Thinset mortar (50 pounds), 4 bags160Most of a bag left over
Scotch Blue pre-taped film12painter's tape with 48 inch plastic film attached
Grout haze remover15most of the pint left over
Horseshoe spacers, 1/8 inch13re-usable
Horseshoe spacers, 1/16 inch13re-usable
Drywall shim (cardboard)12pack of 100, used about 10
Drywall corner bead12
Tile leveling spacers, 1/16 inch14didn't really use these except on the test wall
Tile leveling spacers, 1/8 inch37used about 3/4 of these
Tile leveling shields26re-usable
Tile leveling spin things25re-usable
Diamond cutting wheel for dremel11many left over
Diamond grit sanding blocks15didn't really use these
Diamond hole saw, 1 3/8 inch20
Pre-formed niches100
Silicone caulk, 2 tubes40most of second tube left over
Things in the table above total about US$1400, which is slightly above my SWAG of US$500. Add to that maybe US$100 of miscellaneous small items (rags, plastic putty knives, drop-cloths, nitrile gloves, etc) and maybe US$500 for tools (which can mostly be re-used, if only for tile projects that might never happen). That brings the grand total to the neighborhood of US$2000. Yikes.
