PCB anyone?
02/09/2017 at 18:39 • 0 comments -
Routing complete
02/09/2017 at 06:06 • 0 commentsJust finished up the routing of the board. The updated files are on the Github repository.
Next step is design review and PCB manufacturing.
Here are snapshots of the copper layers:
Enclosures are in! :)
02/06/2017 at 19:45 • 1 commentWent to get some smalls tins over the weekend and routed some of the board.
Here is a picture of the tins for an idea of just how small the board will be:
The board will be using 4 layers for optimal routing. Be on the look out for pics of the routed design. Should be done some time this week.
PCB placement update
02/02/2017 at 05:38 • 2 commentsThe project made a few strides forward today after a fairly long break.
Per request, the board was switched to a single sided population. This will simplify the assembly process for those willing to try it at home with a toaster or hotplate.
The expansion connector was made Lichen PUB compatible by switching to a .1" through hole header. For grins I also added a battery header similar to the one on the Beaglebone Black.
While I was at it, I added some bling to the bottom.
Hopefully the Beagleboard guys will let me keep Boris on there. :)
Work in progress...
01/18/2017 at 18:41 • 0 commentsThe project is currently underway. Latest development has been the discussion and investigation of making it a single sided board for ease of home assembly.
The design is publicly hosted on Github and community support is encouraged.
