Fault label: "Sparky".
2024-03-01
Opened case. Mains cable enters through grommet and is wired to the front-panel mains switch. There is no IEC filtered inlet.
No sparking seen, even if wires poked with an insulated plastic rod (a Biro).
Dials set to maximum, voltage reads 29.75, current limit reads 2.1.5.8.
