![](https://cdn.hackaday.io/images/2228661709722656008.jpg)
This is a switch-mode PSU, so the mains is rectified to around 400 volts DC inside.
Extra care is required to avoid touching this dangerous part of the PCB.
Fault:
Sparking at back of unit.
Suspected cause:
Faulty power connector or EMC capacitors.
Examination:
The power inlet was loose in the PCB, because of repeated cable insertions and no attachment to the case. Thus the strain goes direct to the PCB joints.
Action:
Resoldered power connector joints.
Result:
No sparking.
Status:
Fixed. Awaiting re-assembly and PAT test.
