This is a switch-mode PSU, so the mains is rectified to around 400 volts DC inside.
Extra care is required to avoid touching this dangerous part of the PCB.
Instruction manual:
EX354RD+EX354RT_Instruction_Manual-Iss6.pdf
Fault:
Not marked on unit.
Suspected cause:
Examination:
Action:
Result:
Status:
Unknown.
Photos:
Plenty of room allows passive cooling:
Front panel:
Power inlet area:
