![](https://cdn.hackaday.io/images/2337761711891588775.jpeg)
Tested the first version of the board.
Found a few errors:
1. Missed route
2. Activation of the MUX without an address leads to a short circuit of the zero pin
3. The voltage drop on the Darlington array is too high
Conclusions: soldering the board to the end does not make sense, it is necessary to fix the PCB
