Command set
A project log for TTi 1705 True RMS multimeter teardown
A digital multimeter from the age of through-hole off-the-shelf components
keithKeith 03/10/2024 at 02:460 Comments
The serial port command set is not the same as the GPIB command set.
Automated Test Equipment will have to parse ASCII command/response strings to extract the data.
