PCBs came in! Thanks JLCPCB!!
![](https://cdn.hackaday.io/images/6240751710284041714.jpeg)
Soldered up the boards - Kino in the Design Lab Laser cut a cool outline in plywood that I'm using for the base for testing.
![](https://cdn.hackaday.io/images/6964381710284155765.jpeg)
Boards were soldered and mounted. There were some clearance issues with the meter so some extra drilling needed to be done!
![](https://cdn.hackaday.io/images/8920041710284488424.jpeg)
I'm very happy with the layout - Later this week I will be working on testing using some of the original 65in1 experiments.
