Rev1 Enclosure
A project log for Multimeter
This is my homebrew multimeter design. Included modes are VDC, Ohms, and Capacitance.
marekMarek 03/20/2024 at 03:570 Comments
I have mounted the first revision into an aluminum sheet metal enclosure with some holes cut in it. The first revision has been repurposed into just a voltmeter because there are some problems with the switching circuit.
