- Insert the SIM card into the slot on the back of the board
- Connect 0.96 OLED to Maduino Zero 4G LTE(CAT1 A7670) 's SCL and SDA;
- Connect Temperature and humidity sensor's data pin to Maduino Zero 4G LTE(CAT1 A7670) 's D6;
- Connect Photosensitive resistance module's data pin to Maduino Zero 4G LTE(CAT1 A7670) 's D8;
- Connect Wind Speed Transmitter's data pin to Maduino Zero 4G LTE(CAT1 A7670) 's A0;
