![](https://hackster.imgix.net/uploads/attachments/1691031/image_xje8il7bUs.png?auto=compress%2Cformat&w=740&h=555&fit=max)
ThingSpeak Is The Open IoT Platform With MATLAB Analytics.
- Register and log in to your account
![](https://hackster.imgix.net/uploads/attachments/1691032/image_XD6uqqnULQ.png?auto=compress%2Cformat&w=740&h=555&fit=max)
![](https://hackster.imgix.net/uploads/attachments/1691033/qq20240229181146_QAtdJwYUWG.png?auto=compress%2Cformat&w=740&h=555&fit=max)
- Define the parameter you want in the Channel page and save it
![](https://hackster.imgix.net/uploads/attachments/1691034/qq20240301085301_CwQu2mTpfF.png?auto=compress%2Cformat&w=740&h=555&fit=max)
- On the API keys page you can find out the API key used to write the data, and you can see an example of an API request on the right.
- By accessing the URL of the write channel, you can modify the parameters
