Step 3: Firmware
A project log for LoRa->4G Gateway_Soil monitoring with Cloud Server
To make a simple LoRa-to-4G gateway, you only need an ESP32S3 based 4G LTE module and a LoRa Expansion Board.
makerfabsMakerfabs 03/15/2024 at 06:550 Comments
#include <RadioLib.h>
#include <SPI.h>
HardwareSerial mySerial2(2);
#define DEBUG true
#define IO_RXD2 47
#define IO_TXD2 48
#define IO_GSM_PWRKEY 4
#define IO_GSM_RST    5
// LoRa
#define LORA_MOSI 16 // 23
#define LORA_MISO 18 // 19
#define LORA_SCK 8   // 18
#define LORA_CS 17   // 21
#define LORA_RST 15  // 22
#define LORA_DIO0 9  // 32
#define LORA_DIO1 14 // 35
#define FREQUENCY 915.0
#define BANDWIDTH 125.0
#define SPREADING_FACTOR 9
#define CODING_RATE 7
#define OUTPUT_POWER 10
#define PREAMBLE_LEN 8
#define GAIN 0
SX1276 radio = new Module(LORA_CS, LORA_DIO0, LORA_RST, LORA_DIO1, SPI, SPISettings());
Serial.begin(115200);
    Serial.println(" Test Begin!");
    mySerial2.begin(115200,SERIAL_8N1, IO_RXD2, IO_TXD2);
    pinMode(IO_GSM_RST, OUTPUT);
    digitalWrite(IO_GSM_RST, LOW);
    pinMode(IO_GSM_PWRKEY, OUTPUT);
    digitalWrite(IO_GSM_PWRKEY, HIGH);
    delay(3000);
    digitalWrite(IO_GSM_PWRKEY, LOW);
    SPI.begin(LORA_SCK, LORA_MISO, LORA_MOSI, LORA_CS);
// initialize SX1276 with default settings
    Serial.print(F("[SX1276] Initializing ... "));
    int state = radio.begin(FREQUENCY, BANDWIDTH, SPREADING_FACTOR, CODING_RATE, SX127X_SYNC_WORD, OUTPUT_POWER, PREAMBLE_LEN, GAIN);
    // int state = radio.begin();
    if
(state == ERR_NONE) { Serial.println(F("success!")); } else { Serial.print(F("failed, code ")); Serial.println(state); while (true); } Serial.print(F("Waiting for incoming transmission ... "));
String str;
  int state = radio.receive(str);
  // you can also receive data as byte array
    size_t len = 8;
    byte byteArr[len];
    int state = radio.receive(byteArr, len);
  if (state == ERR_NONE) {
    // packet was successfully received
    // print data of the packet
    Serial.print(F("Data:\t\t\t"));
    Serial.println(str);
    // print RSSI (Received Signal Strength Indicator)
    // of the last received packet
    Serial.print(F("RSSI:\t\t\t"));
    Serial.print(radio.getRSSI());
    Serial.println(F(" dBm"));
    // print SNR (Signal-to-Noise Ratio)
    Serial.print(F("SNR:\t\t\t"));
    Serial.print(radio.getSNR());
    Serial.println(F(" dB"));
    // print frequency error
    Serial.print(F("Frequency error:\t"));
    Serial.print(radio.getFrequencyError());
    Serial.println(F(" Hz"));
  } else if (state == ERR_RX_TIMEOUT) {
    // timeout occurred while waiting for a packet
    //Serial.println(F("timeout!"));
  } else if (state == ERR_CRC_MISMATCH) {
    // packet was received, but is malformed
    Serial.println(F("CRC error!"));
String numbers[10];
int extractNumbers(String input, String numbers[]) {
  int count = 0;
  String number = "";
  for (int i = 0; i < input.length(); i++) {
    char c = input.charAt(i);
    if (isDigit(c) || c == '.') {
      number += c;
    else if (c == ' ' && number != "") {
      numbers[count++] = number;
      number = "";
  if (number != "") {
  return count;
int count = extractNumbers(str, numbers);
for(int i = 0; i < count; i++) {
Serial.println(numbers[i]);
String http_str = "AT+HTTPPARA=\"URL\",\"http://api.thingspeak.com/update?api_key=" + Apikey + "&field1=" + numbers[1] +"&field2=" + numbers[2] + "&field3="+ numbers[3] +"&field4="+ numbers[4]+"&field5="+ numbers[5] +"\"\r\n";
String Apikey = "ANPNRNZOVQO0UBRY";
sendData("AT", 1000, DEBUG);
delay(3000);
sendData("AT+CICCID", 1000, DEBUG);
delay(3000);
sendData("AT+SIMCOMATI", 1000, DEBUG);
delay(3000);
sendData("AT+COPS?", 1000, DEBUG);
delay(3000);
sendData("AT+CPIN?", 3000, DEBUG);
delay(3000);
sendData("AT+CSQ", 1000, DEBUG);
delay(3000);
sendData("AT+CREG?", 1000, DEBUG);
delay(3000);
sendData("AT+CGREG?", 1000, DEBUG);
delay(3000);
sendData("AT+CPSI?", 1000, DEBUG);
delay(3000);
sendData("AT+CGDCONT=1,\"IP\",\"CMNET\"", 1000, DEBUG);
delay(3000);
sendData("AT+CGATT=1", 1000, DEBUG);
delay(3000);
sendData("AT+HTTPINIT\r\n", 2000, DEBUG);
delay(2000);
sendData(http_str, 2000, DEBUG);
delay(2000);
sendData("AT+HTTPACTION=0\r\n", 3000, DEBUG);
delay(2000);
sendData("AT+HTTPTERM\r\n", 3000, DEBUG);
delay(2000);
