4th week
A project log for hydroarm
it's a mechanical arm powered by hydrolics, it has several rotation, one around the z axis and two following the r and teta plane.
edgarfebvinedgar.febvin 06/04/2024 at 07:490 Comments
search for components, we wanted to calculate the size and volume for our seringues. we found our tubes and implemented our sketchs and found the right dimensions.
finally we ended up choosing 10ml seringues, perfect for the delta angles we wanted.
