Dataset from Garden Camera pictures
Head over to the Roboflow website (Roboflow: Give your software the power to see objects in images and video) and sign up for personal use. Click on "Upload Data" on the left menu. Upload all images to be labeled and used for the training. (I had uploaded many more before) Label each image by starting at one corner and drag to the diagonal corner. In the appearing dialog type in the name or select one of the listed ones. After all images are labeled, assign all of them to the dataset. Take a look at the dataset images. On the "Generate" page add some augmentations. Last check and create the dataset. Export Dataset on the next page.
The opening dialog will provide a code snippet to be copied into a Jupyter notebook for accessing the dataset. Hit the copy icon.
Matt Farley
Aidan Porteous
Sumit
Stefan
Yes, delete it Cancel
You are about to report the project "Yolov8 Training on Custom Dataset", please tell us the reason.
