TurtleBot3 WafflePi Energy Logging
Logging the energy usage of all components on the turtlebot3 wafflePi (motors, motor controller, lidar, raspberryPi, etc.)
Public Chat
0 followers
Logging the energy usage of all components on the turtlebot3 wafflePi. Measurements are taken using INA219 current (and voltage) sensors. We use one of the two i2c ports on the RaspberryPi 3B+, by using an i2c multiplexer (tca9548a). These measurements are stored in a file and processed on the robot. The MQTT protocol is used to transfer the processed data from the robot to the end user.
Energy Logging of the Turtlebot3 WafflePi
  • The RaspberryPi tells the multiplexer to measure the power of each INA219 power sensor
  • The multiplexer measures the power for each sensor, one-by-one
Luckily, the sensor takes into account the power usage of itself (the shunt resistor - since we use an external battery supply to power the sensors) - so we don't need to account for the sensor in the the power measurement readings.
Limitation
The measurement readings are too slow with the multiplexer - so we miss information (it takes 23 ms for each sensor to be read and stored in a file - and we use 7 sensors!)
  • Measurements without the multiplexer (only the INA219) takes around 4-5 ms
Future work
The RaspberryPi 3B+ has two i2c ports. So we can get away with not using the i2c multiplexer, which should hopefully increase the measurement reading speed.
We can do this because we use 7 sensors. Each sensor can have 4 different addresses. Meaning we can connect at most 4 i2c devices to the same pin on the RaspberryPi (same bus). Therefore, we can have at most 8 sensors connected to two i2c ports on the RaspberryPi.
  • Get rid of the i2c multiplexer to increase measurement speed (sampling rate)
  • Make new hardware from scratch
    • New current sensor which has a built in integrator (op amp) - so that we average the measurements in analog (real-time)
    • Then we can just sample this averaged measurement, saving computational time
  • 1 × Turtlebot3 WafflePi
  • 1 × TCA9548A I2C multiplexer
  • 1 × INA219 current sensor
  • 1 × External battery supply (optional)
  • 1
    Get to the electronics
    You only need to unscrew (at most) 8 screws on the top of the robot. The ones connecting the top platform to the metal rods at the corners of the robot. (I also unscrewed the raspberryPi camera mount so I could fully detach the top plate).
  • 2
    Locate the power cables
    There are many power/data cables you could measure.
    • Battery --> Motor controller board (MCB)
    • MCB --> Motor 1
    • MCB --> Motor 2
    • MCB --> Bluetooth
    • MCB --> RaspberryPi
    • RaspberryPi --> Lidar (power)
    • RaspberryPi --> Lidar (data)
    • MCB --> Motor (data - this does not work with these current sensors as it distorts the data signal causing the motors to not send/recieve data)
  • 3
    Insert the current sensors
    Once you've located which cables you want to log the energy from - cut & strip the wire and insert your INA219 current sensor inbetween - paying close attention to connecting the supply side to VIN+ and the load side to VIN- (otherwise you get a negative current).
    Then, you can connect VCC, GND, SCL, and SDA to the relevant ports (to the TCA9548A).
View all 4 instructions
