Step 2: SquareLine Design
A project log for 1.28" Screen With ADC
I want to make a thermometer and a weight scale using some sensors and ESP32 board.
makerfabsMakerfabs 04/09/2024 at 01:130 Comments
Choose the Arduino and enter in parameters. According to the features of MaTouch_ESP32-S3 Round SPI TFT with Touch 1.28", the resolution is 240*240, the shape is a circle, and the color depth is 16-bit.
Add the images to assets, and then it allows you to select them and widget components to design the scenes. After, clicking the widget of the list on the Hierarchy panel, you can modify the parameters of the select widget on the Inspector panel, all is determined by your preference.
