MICRO SPECTRUM +
Design and creation of a Spectrum + micro. Designed for 3D printing, based on an orange pi zero2. 5" screen, mechanical keyboard, 3w ampl
I made the design in Fusion 360 with the idea of recreating a spectrum+ with its real keyboard to simulate the games I played in my childhood. For the simulation I used an orange pi zero2 board loaded with a Batocera system. As for the rest of the hardware. We have a powerbank to make it portable, a 5" IPS screen and a 3w stereo amplifier with its respective mini speakers. Without forgetting a mechanical keyboard only with the dedicated letters for playing. The keyboard is connected to an Arduino micro that does the times of a xinput gamepad. All the information about the materials, Arduino program, CAD and STL of the project can be found in the published Telegram channel. I hope someone else can enjoy the project
Weld detail
Battery  case
Printed casing
Element composition
8-bit-classic-arcade-game-116832.mp3
MPEG Video - 4.90 MB - 04/16/2024 at 16:54
Download
44933_Scalesmann_my_bleep_is_inside.mp3
MPEG Video - 4.09 MB - 04/16/2024 at 16:54
Download
fuzzy-logic-classic-arcade-game-116848.mp3
Download
77674_Rayden_ETHN2.mp3
MPEG Video - 8.00 MB - 04/16/2024 at 16:54
Download
dial-up-blues-classic-arcade-game-116844.mp3
Download
View all 34 files
  • 1 × Display 5" IPS https://a.aliexpress.com/_Ew0EUYR
  • 1 × Mini Amplifier 2 channels https://a.aliexpress.com/_EvT2Dux
  • 10 × Mechanical switch Blue https://a.aliexpress.com/_ExGCZeJ
  • 4 × Mechanical switch Black https://a.aliexpress.com/_ExGCZeJ
  • 1 × Pro Micro Arduino AT mega32U4 5v https://a.aliexpress.com/_EIWul2R
View all 25 components
View project log
  • 1
    Step 1
    Print all parts. I have printed them all oriented towards z and with organic supports. With 0.4 nozzle, 0.2 layers and 30% filling. Except on the keys and small elements I have isated layer of 0.12
  • 2
    Step 2
    Insert the M4 and M3 nuts with a fine wire soldering iron. There are 4 of M4 on the base to fix the keyboard and another 4 between the structure and the back cover. And finally 4 of M3 on the base to fix the orange pi zero2 card
  • 3
    Step 3
    Assemble all the keys and fix them in the matrix to later solder joining all the negatives. Next, solder a male dunpot wire to each key. When we do the assembly, the terminals will end up in the inputs of the Arduino pro micro
View all 7 instructions
