On Heat Set Threaded Inserts
A project log for Keyboard Thingo
It's a working title. Making a modular platform for a keyboard + PC related devices.
nickNick 04/11/2024 at 15:050 Comments
A recent module I was working on; a cable organizer and PC power switch, needed to be printed in a few parts.
Naturally, this meant I needed to attach the pieces together. Normally I'd just do this with small self-tapping screws directly into the PLA, but I had none left and couldn't find any for sale in stores or online that would arrive any time soon.
At that point, I figured it might be time to finally give heat-set threaded inserts a chance. I picked up these from amazon, along with this set of bolts.
They arrived the next day and I gave them a try. Turns out, they are remarkably strong and easy to insert.
So long as you aren't putting the strain of opening and closing a laptop hinge a thousand times on them, they are perfectly reliable.
