In the last post we had a look at a simple topology that allows us to switch between a series and a parallel connection of two resistors:
![](https://cdn.hackaday.io/images/1432781715292717864.png)
Now we nest these structures so that we have four resistors:
![](https://cdn.hackaday.io/images/5989291715292743298.png)
The interesting part here is that two of the four switch states of the outer structure don’t provide any new resistance values: With S1a open and S1b bypassing R1b we’re left with R1a. (Again, this assumes the R1a = R1b.) If S1a is closed and S1b in the upper position, then the total resistance will be 0, exactly like with only R1a. Here I assume ideal switches. The series and parallel connection of both R1a and R1b alone is worth it though.
Doing that once more and we get eight resistors, barely visible in this picture, but with a similar effect like with the previous nesting.
![](https://cdn.hackaday.io/images/3433941715292779463.png)
With a total of 14 switches there are 2^14 = 16384 switch states. As briefly discussed, many switch states might lead to the same resistance values (actually, by far not only the two examples described above). In fact, as we will see later, much more than half of the switch states result in a short circuit.
However, states with equal resistances might not be equally suited for the intended application, because in some cases they differ in the power rating we can achieve. But even then, for certain resistance values there might be multiple states with the same resistance and power rating, but with a different number of active switches. This could minimize the contact resistance (but this is not necessarily the case with the dual throw switch) and it might be a good idea to energize as few relays as possible.
This begs the following three questions:
- How many and which distinct resistance values can be selected?
- What power rating can we achieve per resistance value?
- What is the best switch combination (here: least number of relays energized for the highest power rating) to realize each of the selectable resistance values?
To answer this I wrote a small python script that calculates these things for us. I’ll assume all resistors are 10 Ω with a 50W power rating. The results are presented in the following table.
# | Resistance | Number of Valid Switch Combinations | Maximum Power | Energized Switches |
(Ω) | (W) | |||
1 | 0 | 9472 | nan | 4 |
2 | 1.25 | 1 | 400 | 14 |
3 | 1.428571 | 4 | 350 | 13 |
4 | 1.538462 | 4 | 325 | 12 |
5 | 1.666667 | 18 | 300 | 11 |
6 | 1.818182 | 12 | 275 | 11 |
7 | 2 | 48 | 250 | 10 |
8 | 2.142857 | 4 | 233.333333 | 11 |
9 | 2.222222 | 50 | 225 | 9 |
10 | 2.272727 | 4 | 220 | 10 |
11 | 2.307692 | 4 | 216.666667 | 9 |
12 | 2.352941 | 2 | 212.5 | 8 |
13 | 2.5 | 209 | 200 | 7 |
14 | 2.727273 | 8 | 183.333333 | 10 |
15 | 2.857143 | 60 | 175 | 8 |
16 | 2.941176 | 8 | 170 | 9 |
17 | 3 | 8 | 166.666667 | 8 |
18 | 3.076923 | 4 | 162.5 | 7 |
19 | 3.157895 | 8 | 158.333333 | 9 |
20 | 3.333333 | 384 | 150 | 6 |
21 | 3.448276 | 8 | 145 | 8 |
22 | 3.529412 | 8 | 141.666667 | 7 |
23 | 3.636364 | 4 | 137.5 | 6 |
24 | 3.75 | 28 | 133.333333 | 8 |
25 | 4 | 370 | 125 | 5 |
26 | 4.166667 | 28 | 120 | 7 |
27 | 4.285714 | 28 | 116.666667 | 6 |
28 | 4.444444 | 14 | 112.5 | 5 |
29 | 4.615385 | 8 | 108.333333 | 8 |
30 | 5 | 933 | 400 | 6 |
31 | 5.263158 | 8 | 95 | 7 |
32 | 5.454545 | 8 | 91.6666667 | 6 |
33 | 5.714286 | 4 | 87.5 | 5 |
34 | 5.833333 | 4 | 262.5 | 11 |
35 | 6 | 32 | 187.5 | 7 |
36 | 6.5 | 4 | 203.125 | 10 |
37 | 6.666667 | 356 | 300 | 5 |
38 | 7.142857 | 32 | 280 | 6 |
39 | 7.333333 | 8 | 229.166667 | 9 |
40 | 7.5 | 50 | 266.666667 | 5 |
41 | 8 | 20 | 250 | 4 |
42 | 8.333333 | 28 | 166.666667 | 8 |
43 | 8.571429 | 28 | 131.25 | 6 |
44 | 9 | 28 | 180 | 7 |
45 | 9.166667 | 4 | 103.125 | 9 |
46 | 9.375 | 8 | 120 | 7 |
47 | 10 | 1074 | 200 | 3 |
48 | 10.666667 | 8 | 120 | 7 |
49 | 10.909091 | 4 | 103.125 | 5 |
50 | 11.111111 | 28 | 180 | 5 |
51 | 11.666667 | 28 | 131.25 | 6 |
52 | 12 | 28 | 166.666667 | 4 |
53 | 12.5 | 20 | 250 | 6 |
54 | 13.333333 | 50 | 266.666667 | 7 |
55 | 13.636364 | 8 | 229.166667 | 5 |
56 | 14 | 32 | 280 | 6 |
57 | 15 | 356 | 300 | 4 |
58 | 15.384615 | 4 | 203.125 | 4 |
59 | 16.666667 | 32 | 187.5 | 5 |
60 | 17.142857 | 4 | 262.5 | 3 |
61 | 17.5 | 4 | 87.5 | 9 |
62 | 18.333333 | 8 | 91.6666667 | 8 |
63 | 19 | 8 | 95 | 7 |
64 | 20 | 933 | 400 | 2 |
65 | 21.666667 | 8 | 108.333333 | 6 |
66 | 22.5 | 14 | 112.5 | 7 |
67 | 23.333333 | 28 | 116.666667 | 6 |
68 | 24 | 28 | 120 | 5 |
69 | 25 | 370 | 125 | 3 |
70 | 26.666667 | 28 | 133.333333 | 4 |
71 | 27.5 | 4 | 137.5 | 8 |
72 | 28.333333 | 8 | 141.666667 | 7 |
73 | 29 | 8 | 145 | 6 |
74 | 30 | 384 | 150 | 2 |
75 | 31.666667 | 8 | 158.333333 | 5 |
76 | 32.5 | 4 | 162.5 | 7 |
77 | 33.333333 | 8 | 166.666667 | 6 |
78 | 34 | 8 | 170 | 5 |
79 | 35 | 88 | 175 | 4 |
80 | 36.666667 | 8 | 183.333333 | 4 |
81 | 40 | 209 | 200 | 1 |
82 | 42.5 | 2 | 212.5 | 6 |
83 | 43.333333 | 4 | 216.666667 | 5 |
84 | 44 | 4 | 220 | 4 |
85 | 45 | 50 | 225 | 3 |
86 | 46.666667 | 4 | 233.333333 | 3 |
87 | 50 | 48 | 250 | 2 |
88 | 55 | 12 | 275 | 3 |
89 | 60 | 18 | 300 | 1 |
90 | 65 | 4 | 325 | 2 |
91 | 70 | 4 | 350 | 1 |
92 | 80 | 1 | 400 | 0 |
Since the selected topology does not inherently allow to open the circuit, an additional series-connected relay is required. This relay is not included in the total number of energized relays.
