Starting Point
A project log for Room Heating And Lighting Control
A cheap and easy to configure multi room lighting and heating control panel. Preconfigured for Radiator Valves and Ikea Dimmable Lights.
john-gilmourJohn Gilmour 04/15/2024 at 01:540 Comments
Most of what is needed to get started is uploaded, including the panel configuration file.  I will upload the Node Red flows once I have removed my MQTT password and provide more instructions on using this.
I will be adding more detail and happy to answer questions or explain specific areas
