It took me a good 40 minutes and a part of my fingernail, but I managed to abuse a standard NEMA17 mount to fit M5 bolts at the spacing required for the carriage, using a handdrill, pliers and a screwdriver.
![](https://cdn.hackaday.io/images/5278561714517646872.jpg)
Installed it
![](https://cdn.hackaday.io/images/5300151714517814017.jpg)
And the first extruder is in place... Now I still need to figure out where to install the BLTouch. Probably going to mount an L bracket between the motor and the extruder. <-- scrap that...
4 tie wraps + 2 pieces of a wooden fork as a spacer. That BLTouch is going nowhere...
![](https://cdn.hackaday.io/images/7649901714523654638.jpg)
