PCIe mini XLR brackets
A project log for Bootstrap 3D Printer
Bootstrap: A large volume 3d printer that can be built at home without requiring any custom 3d printed or machined parts.
es-pronkE/S Pronk 05/03/2024 at 00:470 Comments
I'm trying to connect my motors to the board in a nice way. I thought it might be nice to use mini-XLR connectors and drill holes in a blank PCIe bracket.
I do not recommend doing this with a hand drill
However, this is my personal log of how I did it with pliers and a handdrill...
Step 1: Cut out parts of the grill where the connectors are going to be placed
Then, with an "erbauer cone drill bit" make the flower shapes into hole shapes but do so with the drill put IN REVERSE.
They will still be too small to fit the connector, but now you can carefully try drilling with the drill in the forward direction. Make small increments until the connector can be pushed through
Then all that's left is finish up, and in a later post we'll be wiring the motor controller outputs to these ports.
