List of Basic Commands
General
• AT
Responds with OK, no other operation is performed. When auto baudrate is enbled, it's necessary to begin with this command after reset. Send it a few times until an OK response is received. Usually responds for the 2nd command. After 5-6 tries you can assume something went wrong and reset the M95.
• ATE0
Disable echo. Default is enabled. If it's enabled, you get back all the commands you send. Useful for a human communicating manually but unnecessary for a microcontroller.
• AT+QINISTAT
Check the initialization state of the M95. After powering on, it is necessary to wait for the module to initialize. The init state has to be '3' before doing any further setup.
• AT+CPBF
Find phone book entries. This does a string search in the phonebook and returns the results. This is useful if you need to store some information on the SIM card.
• AT+CGREG
Request the network status (for data connection): connected, in data roaming or searching for network.
• AT+CPIN
Request the PIN state of the SIM. If the SIM card needs a PIN, you can enter it with this command.
• AT+CFUN
With this command you can do a software reset of the M95.
• AT+COPS
Get cellular operator info.
• AT+CSQ
Get signal quality info.
SMS
AT+CMGF
Select the SMS message format. 0 is for binary mode, 1 is for text mode. I recommend text mode for ease of use.
• AT+CMGL="REC UNREAD"
Receive all unread messages. Lists all the unread messages incl. header information and message text.
• AT+CMGS
Send an SMS.
• AT+CMGD=1,2
Deletes all read and sent mesages. Unread and unsent are preserved. Useful for periodic cleanup of the internal memory.
Data connection
See the "GSM TCPIP Recommended Process" document.
• AT+QIREGAPP
Start the TCP/IP network stack and set up the data communication.
• AT+QIACT
Activate the data connection.
• AT+QIDEACT
Deativate the data connection.
• AT+QIOPEN
Open a TCP or UDP socket and connnect to the host.
• AT+QICLOSE
Disconnect and close a socket.
• AT+QISEND
Send data thru an open socket.
• AT+QIRD
Receive data from an open socket.
• AT+QINDI
Set the mode for how data are received from sockets. Setting this to '1' means that you will receive data with the poll command AT+QIRD.
_______
That's all. These are all the commands that are required to operate the M95 module.
