The motor in this scooter is a separate field excited DC brushed motor. The old motor ECU only had the 1 field connection, I've rewired the motor to bring both field connections out to the Curtis Sepex controller. Have terminated the field windings with 90 degree spade connectors because of lack of space in the motor eco box.
![](https://cdn.hackaday.io/images/1913381719075326746.jpg)
