Design Overview
Also see the CC BY-NC-SA 4.0 license.
Project Introduction
The power module designed based on SC8721.The SC8721 is a buck-boost ic.
Features
- 2.7V to 22V input voltag range
- 2.7V to 22V output voltage range(If the ic is sc8721b, the output voltage range is 0.6V to 22V)
- Through its I2C interface, user can program the output voltage and output current limit and switching frequency
- Provide routine code, software platform is Arduino, and hardware platform is ESP32s3
Project SCH
![](https://cdn.hackaday.io/images/2950941716372220145.png)
