Instructions:
## Prints
For the whole setup you need to print the following parts. Some might need support with your printer or could be seperated and put together later with glue.
### For the Case
- case_with_socket
- gutter_kirby
- kirby (I mid-print changed the filament twice to gett all his colors. First white, then pink and finally black)
- nut_grippy
### For the star light
- star_body
- star_lid
- tube_segment_bottom_end
- tube_segment_top_end
- tube_segment_tall / _small (as many as you need)
### For the arm
- barrel-holder (if you use one of [these](https://www.amazon.de/MANDDLAB-St%C3%BCck-Power-Socket-Barrel-Type/dp/B0CPSDVC7F/ref=sr_1_4?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=2WBXCLZCNMPF&dib=eyJ2IjoiMSJ9.guZuSlaP26fvNbe4wWFNZlAJTJdVzCRr6UH_72LYkHdxLNXkJETF3Pv_oqJb9QMQGqYQP-LezKbY5taMy_z2pkXckWNmB3wzDbtw5cQn1kWLHnqR1xFArxiqE2miYEFn39ff_99N6Tocv7fepbNM9vH6Id_dVkw5rVzQ8eHmMm03mto6uUO6sI_bUzCJW9X6EeJrl9fT5oZMO5Hwk_W8HWG0JUCq1us75PPIZ9W3w3c.12IWkYNWAlLvvaL2XQsQgK-vrytKtu96mUdK-LDDD4c&dib_tag=se&keywords=barrel+jack+socket&qid=1714686247&sprefix=barrel+jack+socket%2Caps%2C129&sr=8-4) for the the power connector)
If you want to go without the arm, just leave these parts out. If you want to replace kirby with a honey-comb gutter print "gutter" instead of "gutter_kirby" and "kirby"
## What else is needed
A 12v 120mm x 120mm x 25mm DC or PWM Fan. [That's the one I used](https://www.amazon.de/gp/product/B07GB6D7VQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1)
The flexible arm i used is [here](https://www.amazon.de/gp/product/B0B4FWXZZ1/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1)
A 12v power supply, if light is used at least with 0.42A. Like this one [these](https://www.amazon.de/Netzteil-AGOTD-Transformator-220-240V-Streifen-schwarz/dp/B0CGD23B6G/ref=sr_1_6?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=2YHIWOQ8FDNSG&dib=eyJ2IjoiMSJ9.ZwohkQVYROXaQGaP3MM9hs6uFTcIGLyyIJj29SrTL0l8w2N4960sQ8v1DqED2E6HK_gemIYbGDjw0U6qM47kYhCpua-VwasrwI7AAcp_5vvFwc58SVb2FG8L-deYxNhFBZaiMaWGs5yawBxJ028padGPMElLYdGUmuaPKwHTxiWP7L6bo5NGW3Al46xC8M3ygrsR0QTMrZaF7kj53rsVnPYiA_Qwdt48CLjlar-03krm08suPajt0-oIbUsWXkWL9-dyHAWrKy_DyE15hP2BBpmCemyjLqLJGlVaRCwxq7M.EJ3ddWtVreEMYJQ2HtBGqHIx905W7jwDH_ezKbub0vQ&dib_tag=se&keywords=12v%2Bpower%2Bsupply&qid=1714684594&s=ce-de&sprefix=12v%2Bpower%2Bsupply%2Celectronics%2C132&sr=1-6&th=1)
That kind of [LED](https://www.amazon.de/Auting-Warmwei%C3%9F-Halogenlampen-Energiesparlampe-Dimmbar/dp/B0BZ8986C3/ref=dealz_related_t1_d_sccl_2_4/260-4366050-2125305?pd_rd_w=RS0K5&content-id=amzn1.sym.1f4afbac-81ba-481c-b3ef-024210f3433c&pf_rd_p=1f4afbac-81ba-481c-b3ef-024210f3433c&pf_rd_r=V06CSP7RFDRMMPTQPRR7&pd_rd_wg=TiZv5&pd_rd_r=f2c80e32-9223-4929-a6e4-4915243f536b&pd_rd_i=B0BZ8986C3&th=1)
Two of these [charcoal mats](https://www.amazon.de/Aktivkohlefilter-St%C3%BCck-13cm-L%C3%B6ten-Rauchabsorbern/dp/B07WR72S4Y/ref=sr_1_3?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=3EFLHBUR8DWCE&dib=eyJ2IjoiMSJ9.HigXdEQeoB6wkcE2wnbu1dh-NqVR6x6y179QlL-yyY0yuaM1nsw_hYHF_9MgLBc9LpE1dIjbtqF2iE7xWRfeJIrmgxOVp75xfrZlXSMm0x0h2vv2Zqgajv1qnBJ9tGAOn5xiY2DtxXTjIC8_K2Ju-Fqil8ddu8KRImy_RJtnNlGnzmRfusxcuUE98BsCG49qAGYB9r9KcsAiM05JoFAa5xKDrLCA8Cb7KDobfrKsLzJic9iUSL4Yr1YVHe0nFBlE6LSEjmIASQ07IHDXK75ZoK920hbTxNeBjc3HnhYcKaA.WdyB7ydsRBqoRKroVIsXOJN5A5tOhIApulW9i0a6MEE&dib_tag=se&keywords=120+aktivkohle+matte&qid=1714685099&s=kitchen&sprefix=120+aktivkohle+matt%2Ckitchen%2C161&sr=1-3)
and a simple on/off switch that fit's into a 6mm x 10mm hole. like [this one](https://www.amazon.de/GUMEI-Position-Vertikaler-Schiebeschalter-SS12D00G3/dp/B09BZ8LF55/ref=sr_1_57?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=2KCQCJR1JU28I&dib=eyJ2IjoiMSJ9.skTJpcTDSid2U0OT67lLeLBdeGyGBBJgDwAHuLg7Iut1YNx53MQ3gl0g-BDj7kv_fnvf4Yu8UiFKR6-jOcbwgrcYlnyahaznLxRzqe7TsRDh8Rechz0JQtUL9TctKndCFh9H8zjT4VihiVZNCgvanq0BZsfTkouHHcK1BMhSoTbV6Qrw523qBPx62K54tBxX.6OwzHa8xuUdmjYGuqizpgBFj51LC5CYaGe_hbI3N3eo&dib_tag=se&keywords=on+off+switch+10mm+6mm&qid=1714685383&sprefix=on+off+switch+10mm+6mm%2Caps%2C131&sr=8-57&xpid=eCB83v2zy7zDA) otherwise the hole should be adjusted.
some [light diffusing foil](https://www.amazon.de/VBS-Lampenfolie-0-5mm/dp/B008CO4WQY/ref=sr_1_6?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=3D4GYOI6QVK26&dib=eyJ2IjoiMSJ9.l5_FFX_yeAxfdsvC6WYg3TxlyDgw8We4y9Iw_Rh9xqURqM7OBfdNabVfF7SNhjByKIC829-huWhFSO40e9CY5VO6v-FZHaKLM_WoPNKzELsSCVkawke3vztQKvMBGd34lZA0HLA09wRH1WIx8tvwaUsgznAEpx4hgLaUSP9Unry1xumqtttEdHs7pJxm3v5p3lW1XcaQw_4JXlPSIB_UTWg3u-9P3kEL57JmYt-hEZM.Z-CrWKIlHV8EjhMvNd0_KYe5gx6o4B9XU1-241KSaeI&dib_tag=se&keywords=diffusor+folie&qid=1714685569&sprefix=diffuer+folie%2Caps%2C139&sr=8-6) to cover the star.
Also some superglue, cables and some tools.
## Assembly
The parts click-fit together o need to be fixated with all purpose screws. The holes for the arm that holds the star still need to be drilled. you can either use metric screws with nuts or regular ones or glue it in position.
The LED and the fan are wired in parallel to the power source. I added the switch to the live wire to turn it on and off in one go. The inside of the star is covered with aluminium tape e and covered in milky foil.
The flexible arm needs a little disassembly first. The whole cellphone mount needs to go so only the ball joint at the top stays. The nut goes on the arm first, the ball clicks into the threaded end and the arm gets fixated by screwing the nut onto it.
