![](https://cdn.hackaday.io/images/1137851718817360300.jpg)
Pomelo detector on the shoulders of giants
I got the scintillators I intended to use with this detector and have some performance plots with them in this project log. With them the hand-held detector is also starting to look better. I added top & bottom laser cut acrylic plates as basic protection of both electronics as well as of fingers from the ~80V generated by the bias circuit.
The detector consists of a top user interface & connectivity board based on the ESP32-C6 (Pomelo Zest), and a bottom gamma spectroscopy board (Pomelo Core). The power consumption of these two boards can be measured individually:
Pomelo Core:
- active: ~3 mA at background radiation levels
Pomelo Zest:
- active, connected to WiFi: 50 mA
- active, LCD backlight on: 70 mA
- active: 40 mA
- light sleep: 0.7 mA
- deep sleep: 0.35 mA
- deep sleep with SD card inserted: 0.65 mA
On future board revisions I intend to gate the power to the LCD and SD card.
Here are some pictures of the detector with its laser cut acrylic protection plates.
![](https://cdn.hackaday.io/images/7854481718818078170.jpg)
![](https://cdn.hackaday.io/images/1934101718818087702.jpg)
