A project log for Kitchen Timer
We're building a Kitchen timer! The project is heavily inspired by "REST: Kitchen timer" by mkdxdx [Hackaday.io].
nicolas-perozziNicolas Perozzi 06/26/2024 at 14:060 Comments
Choosing bearings for the 3d printed gears.
The dial will drive the rotary encoder using a "planetary gear" type setup. One of the planet gears will have the encoder as the shaft but the other two gears, which work as support, will rotate freely over bearings. The free-rotating gears will be fixed to the PCB by a M3 screw and separated from it by a washer.
These are the requirements that I was considering:
I ended up settling for the following open bearings with OD: 8mm, ID: 3mm, width: 3mm
