ver0.01 Components and first prototype.
A project log for Mona Lisa ParaFoil
A lightweight compact fabric/stiffer material Parafoil underslung is a raspberry pi for control and camera feed. See notes this has evolved
slncioSlncio 02/13/2017 at 22:200 Comments
Scaled it back and salvaged what I had already around the house put together my roungh BOM on the floor. With a couple of additions. Wooden dowl probably for the main spar. And a cheap IR controlled UFO from a local department store to provide power for the 0.01 version. Weight is key so I've cut back all structure from the power and control units and will tape and stick it together as lightweight/cheap and throwaway as possible for the first version.
