New print
A project log for Braille Compact Printing Press
Compact printing press for nurses, helpers, teachers and anyone else who needs to leave small notes for people who read braille.
haydn-joneshaydn jones 03/30/2017 at 11:540 Comments
Here is an ultra compact version I tested. I set the openscad file to standard library size braille which works well, but a couple of easily avoidable issues arose. Firstly I set the tolerance too low. I thought 0.2 mm would be fine for my printer, but the pieces fit too tight. Secondly I made the depth for the tiles too low and they become too fiddly. I would recommend to anyone making these that they print a 2 cell wide test print with at least a 3mm cell thickness, and share there findings for others to get the best results.
