Bread Boarding the LCD panel
A project log for Portable Chaos Monkey
Information Radiator, Software Build Monitor
guy-winterbothamGuy Winterbotham 08/10/2014 at 21:530 Comments
I left the monkey alone for starters and started injecting control points via the MOSFET and LCD panel.
The small micro was for testing. In the end I needed something a little bigger. The paper jammed in the socket was to overcome an issue with the IMP, Pin 1 and the Sparkfun socket.
