the Sensors
A project log for Tachtastic - a fantastic Tachometer
I know, a cheesy name - an AVR ATMega8 tachometer, with external sensors and a good design experience.
ejaadtechEjaadTech 07/22/2014 at 07:120 Comments
Here are the 2 sensors I designed for this tachometer,
1 is a reflective type, meaning it will detect movement based on the reflection of light and the other is a pass through, the counting is done when light is CUT.
