I want to build a memory card replacement for the original Sony PlayStation with enough storage to hold all the saves even the most enthusiastic of PlayStation gamers will need, while still being compatible with the original console's hardware, using the memory card port instead of the parallel port, and with redundancy to alleviate the worry of data corruption.
