Putting electronics together
A project log for CNC Add-on: Rot. Laser Soldering Paste applicator
Using a cheap tire compressor, driven by a stepper motor, to apply solder paste from a syringe and then soldering small wires to components.
AltMarcxsAltMarcxs 09/29/2014 at 03:500 Comments
4 axis or compressor stepper driver mounted: see https://hackaday.io/project/1970/log/10123
Laser control unit mounted on the Y axis:
The main control unit been tested.
