Both the Makeup Organizer and the Desktop Organizer are ready now with all the findings after making the samples. Guys, CNC manufacturing optimization is a lot about feeds, speeds, and tool changing.
Fusion 360 makes life easier as it integrates a CAM module / simulation. This allows to update the design without having to export and move files back and forth. It still can't go to the lumberyard for you though.
Now it is just a matter of making the last prototype for each one, and on to the short run!
