Captains Log #7
A project log for C.H.I.P SmartPhone
A Fully Open Source SmartPhone Using The C.H.I.P Pro
Ricardo FerroRicardo Ferro 04/25/2017 at 06:320 Comments
Redesigned part of the PCB to be smaller after I found out that someone was able to boot from the GPIO which is great since it saves money on IC chip and leaves the SPI available. The PCB is labeled "ChipSmartPhone Core Rev 0.2 "on GitHub. On rev 0.3 I will add through holes around the CHIPPro for adding headers and add a power button.
