Captains Log #4
A project log for C.H.I.P SmartPhone
A Fully Open Source SmartPhone Using The C.H.I.P Pro
ricardo-ferroRicardo Ferro 04/19/2017 at 06:290 Comments
Digikey didnt have a specific sim card tray for the pcb, which is fine since I decided to order a simcard+ micro sd card combo 2.2.h which should be great for the CHIP pro since it lacks a SD card. I couldn't find a library for it, which is fine.I'll just make a custom library based of an different similar existing component.
