Modification of Infrared Thermometer
A project log for DIY Thermal Camera
A $50 thermal camera using a non-contact thermometer, 2 servos, and an Arduino
Michael ShaubMichael Shaub 03/26/2017 at 14:470 Comments
Luckily, the thermometer's circuit board has an unpopulated header that's ready for hacking. I wanted to keep my setup flexible so I used an old cable with the right number of wires and soldered a set of header pins onto the board. By making a hole in the thermometer case the cable can be removed anytime.
According to this Instructable the pin out is:
(photos to come)
