Day 1: V1 Firmware and IDE
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 09/10/2023 at 05:310 Comments
And so it begins,
This is my Day 1 post. This is the firmware designed to run on the original STMF405 based Edge Boards (coming soon)
Basically you would drop a board on the canvas, export a .json file and when you had the same network of boards on the network the zorg board would pass out all the subscriptions.
Link to github repo for the IDE: https://github.com/evezor/EdgeIDE
Link to github repo for the firmware: https://github.com/evezor/Edge_Boards
Please note that these versions are now deprecated, but I believe it's still useful to share.
Huge Thank you to James, Carl and Joe for your help getting this together!
