Day 8: Edge Board Weather Station
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 09/15/2023 at 10:553 Comments
This weather station board features a barometric pressure sensor, an ambient light sensor and a temperature and humidity sensor.
Source files can be found here: https://github.com/evezor/v0_weather_station_board
This board uses the Evezor Stamp STMF405 MCU
source: https://github.com/evezor/Evezor-Stamp-STMF405
Paul McClay wrote 09/15/2023 at 18:56 point
Hey -- neat to see new activity on an ambitious project!
If you want to dress for photos, you can clean up FR4 perf board edges right quick on a coarse sharpening stone. IME water captures the mean glass dust and lead falls out of the water.
https://www.instructables.com/Clean-Cut-FR4-Perfboard-ProtoboardPrototype-PCB/#step4
anfroholic wrote 09/16/2023 at 11:15 point
Awesome! Thanks for the tip. Although I don't think I've made a horrible little bodge board since that thing.  I may be able to use that tip on other places tho. I don't like the edges sometimes with v-cuts or mousebites. Thanks again!
Paul McClay wrote 09/16/2023 at 18:15 point
You're welcome :}. Unplated or lead-free edges you could do trivially under running water (assuming wastewater treatment does something sensible with glass & resin dust). Prolly a single stroke on a diamond stone for a v-cut edge.
