Day 19: Edge Board 5up Digital Input Board
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 09/27/2023 at 22:050 Comments
An edge board containing five opto isolated inputs. All inputs are active HIGH. Each input comes with an input pin, a 5v and a gnd connection.
If I were to do this again, I would probably make a jumper that can switch between the 5v and whatever the bus voltage was.
source files can be found here: https://github.com/evezor/v0_5up_digital_input_board
This board uses the Evezor Stamp STMF405 MCU
source: https://github.com/evezor/Evezor-Stamp-STMF405
