Final(ish) third generation hardware
A project log for OSUG: Open-Source Underwater Glider
A versatile autonomous environmental drone using a buoyancy engine
alexwalexw 10/07/2017 at 16:130 Comments
I have gone over the glider CAD model and I have changed the parts so that no post processing is required (unless I've missed something).
Within the Onshape model, the test prints should be printed first and they are used to select values for the component variables.
I am aware there is currently a lack of instructions for the third generation of hardware but all the images of the assembly can be found in the dropbox folder.
I should update the project page soon with full instructions for the assembly of the glider.
