Decide - OpenCV, Motion, or homebrew?
A project log for Garage Security
A front-end to the Raspberry Pi that uses the NoIR camera & GPIO for remote residential door control
DeckerEgoDeckerEgo 07/28/2014 at 01:100 Comments
The README.md in GitHub still says OpenCV is required, and I also make mention of the Motion subsystem in the project. I started with Motion, tried to advance things with OpenCV, however the current state of the software project has a homebrew imaging solution.
I need to finally make a decision on what the appropriate path forward is. I'm going to do some tweaking on the homebrew solution - if it (finally) works I'll clean up the documentation and point everything to homebrew. Otherwise I'll need to decide between OpenCV and Motion... likely OpenCV.
