Noise and Insertion Loss using Band 20 Duplexer
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 04/14/2017 at 15:110 Comments
The animation below shows really clearly the noise created and the loss of signal incurred when the CTS USD020 duplexer is used. For comparison, when the duplexer, which is basically a pair of band filters, is used I ramped up the LNA (low noise amplifier) by 4 dB. This is not necessarily bad as the advantages of having a reasonably good band pass filter are enormous.
