Final PCB Design
A project log for ESP IoT Controller
A controller for all your IoT needs.
JeremiasJeremias 04/02/2017 at 14:460 Comments
I have access to a small CNC-Milling machine. Therefore I designed an 1-layer board with relative thick traces 0.4mm (15.75 mils). I wasn't able to route everything on the top layer, so I have to use some jumper wires for the bottom layer.
